Off Roading double steering stabilizer ?
Off Roading More land closure
Competition Buda Dyno Day 2010
when I recently did the steering upgrade from inverted y to the T. I lost oem steering stabilizer. I have been looking at options for a double at topguncustomz they have a skyjacker white shock system cheaper money wise and a bilstein double also more money. wondering what others have used and are happy with. since I have bigger tires now and soon new ball joints and steering change I need to do this. so let me know what you think. I would even consider a bigger single system if that would be just as good. thanks for the comments
__________________
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-DD3600 TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2 " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" RCD LONG ARM LIFT. THANKS RIP
US. MARINE PROUDLY SERVED 1993-2006
I dont think you will be able to tell the difference between the Skyjacker and Bilstein steering stabilizers, with that said the finish will hold up much better with the Bilsteins if that matters to you. The stabilizers take quite a pounding from road gravel.
