2nd Gen Non-Engine/Transmission Down pipe to turbo elbow connection
Engine/Transmission (1998.5 - 2002) Crank case vent tube
2nd Gen Non-Engine/Transmission 2001 Dash Replacement Help
TRAMPLINEMAN
This is for a '99 Cummins. I'm wondering if anyone knows the size of the 2 bolts that hold the down pipe flange to the turbo elbow flange!? Thanks in advance!
When I installed my Pac Brake many years ago, it had to be a 9/16 or a 13mm, if my feeble old mind isn't trickin' me. Or some other common size.
Whatever it is, just climb under the truck, and if you have standards or metrics, and you will be able to do or undo as you please.
I lost one of mine and used a manifold to head bolt, it was longer than I needed so I shimmed it. I belive there 10MM as I recall. When done double check that they are still there and tight periodically.
