Details here: TDR Privileges
I went to a local muffler shop that was set up to bend 3" pipe (some shops are'nt). He fixed me up with a 3" downpipe and welded it to my existing banks 3" exhaust. A 3" downpipe fits nicely under the floor and around the transmission adapter but you can probably go bigger.
On my conversion I purchased a complete new 4" exhaust for a 94-97 Powerstroke for about $225. I cut and welded pieces of the PS downpipe together with pieces of the original Cummins downpipe to get down to the rest of the exhaust. Worked well and was cheap too.
Here's an example of how I did cutting and rewelding of a 4" stainless system to make it fit a 1985 Ram. Just like the other post, I cut wedges out of the sections that needed to turn under the passenger footwell quickly. The extra materials laying around afterword went into heat shields. It welded up ok with 308 Mig wire.
I just noticed what looks like a vacuum pump between your alternator and AC compressor. Is that your idea or did the engine come that way? Just curious.
I took the vacuum pump idea from a friend who put a 4bt in an older Dakota. It's a Ford vacuum pump offered on some of their diesels. I saw it on eBay and bought the pulley from a Ford dealer.
Sweeeet. It's much easier/cheaper to change out a dead Ford vacuum pump than a Cummins. I have been flirting with the idea of converting to hydroboost. Parts would cost me about $260. Of course I still have to have vacuum for the HVAC system.
