Do you believe in Dowsing or Divining Rods to locate underground water for a shallow irrigation well for our garden. I don't believe the ground water is very deep, when the footings of our pole barn were dug I asked the contractor if he needed me to fetch the garden hose to mix up the concrete? he pointed to the 5' deep hole and it was filling with water.
Big,
Yes I do believe in Dowsing, Divining Rods and Water Witching to locate underground water sources as one that can do just that. Do not ask me the exact science behind it. I tried to read up on how it works and why, still coming away confused and no definitive answers. Scientists, geologists, hydrologists are of mixed camps as far as whether it actually works, why or why not it works and how it works.
This I do know, it doesn't work for all people. And for those it does work, it doesn't work the same way. Some people it doesn't work at all for.
Some or maybe most people use a forked sapling branch, usually off something like a apple tree, willow tree or other like softwood. Some use divining rods usually something like 1/16" diameter brazing rod. And some people can and do use both.
Personally I am one of those that use brazing rods, about 1/16" diameter and approximately 30" long, bent into a 90 degree 6" long handles that can be held so that the rods protrude out in front of me.
I have tried the forked sapling branches several times, for me they DON'T work and never have. But the rods have worked every time.
I dowsed or witched my own well with accuracy that was spooky, prior to drilling it. I had 3 well drillers come out and each one used a Dowser, plus experience and science. Each did a dowsing and marked a spot. Prior to the drillers dowsing it, I dowsed it. Using graph/mechanical drawing paper and a grid I mapped my location. I removed my markers and then had each driller do the same thing. After each had dowsed, marked it and left, I made a grid map of each and removed their markers prior to the next driller showing up. Two of the 3 drillers were within 3 feet of my dowsing map. The third driller, well that was a different story, and due to his lack of professionalism and unwillingness to get into details of the drilling process, I let him go.
Every driller where I previously lived in the Sierra Nevada's all used a dowser in addition to technology and science.
I know this sounds over the top, but when you are paying for every inch the drill bit goes into the ground, regardless of if the hole produces water or not, you do whatever you can to push the odds in your favor.
I have found water lines, sprinkler systems, sewer and drain lines, etc. It works every time.
Now as far as having a water table like you do, and so close to the surface, I can only guess that the rods reaction would be the strongest in the area where the water table is at it's most volume, closest to the surface.
When I have shown this to friends and relatives alike the reactions range from fear, bewilderment or like I just stepped off another planet.
So there you go, just another odd mystery of the universe.
~C
