You're seeing exactly the kind of junk happen that just happened to mine as I was approaching 20k miles. I had been getting P2262 so took it to the dealer and they installed the AX flash (mines an 07). Went on vacation and 800 miles into the trip crusing 65, the warnings started. They were intermittent, they'd come and go, disappear, reappear, etc.
Two dealers later and they confirmed my truck's sofware was not updated properly and the overhead should have also had a TSB applied to it when it was flashed to the AX revision. Regardless, I had codes telling them the DPF was overtemperature (P200C) and the efficiency of it was flagged with 3 other codes. However, no parts were in the system so with a 20% plugged DPF at that time, I had to get home and didn't get any codes going back.
Right now I'm haggling with a local dealer who doesn't communicate with other dealers and believes flashing and regenerating is the cure for all these trucks problems. Just because the previous dealer cleared the codes during their diagnosis, this dealer won't do a thing (yet). I'm pulling receipts now to show proof of the problems.
If we really have the latest TSB done completely right, I understand there is a chance that we may be over the hump with some of these problems. They key is getting all the crap built up in the system out of it before any new components are installed downstream or you'll just have more problems. If they have to drill the turbo for flushing, one tech told me to make sure the exhaust is disconnected from the turbo during the process so it can blow out any metal particles and avoid damaging the emissions hardware in the exhaust.
7. 5 6. 7 27,700 as of today. Had 3 instances of engine light which disappeared one day later each time. Unit not running well in the morning... like it is choking or something. Pulled to a stop, restart engine and things ok. Took to dealer today, unit needs new Turbo and new DPF, they had to order it and will take truck back there on Monday.Just thought I would give an update for anyone interested in this thread -
Went to Dallas Dodge today and had the service manager verify that my truck had the latest engine/transmission flash (it already had latest version) and also had him check to make sure the body control computer (overhead readout) was updated - it was not - so he updated to the latest version and also turned on day time running lights for me (free of charge).
Long story short I'm hoping this is indeed why I and others have been getting the odd behavior of the overhead status (EVIC) readings. I guess the dealer did not realize (if this is the case) that whenever they do a flash for the engine, they should also do the body control computer.
Of course I just had this done - so I'm only guessing at this point that the problem is solved. I'll keep y'all posted.
On a side note - I asked him how many P2262 codes he had dealt with (he knew the code immediately). Claims there have been "some" and again told me to use the exhaust brake all the time (which I love to do anyway) and also said he is putting together a new service package that includes cleaning the turbo with the drill/tap/solution we all know about. Interesting to me - it sounds like a good plan, but it might also be a sneaky way for dodge to get the less informed to foot the bill for the soot accumulation problem (which luckily I have not had to date - knock on wood).
-J
