500 ppm fuel is still legal for sale as "off road" fuel, but not as "on road" fuel after Jan 1 2009. ALL "on-road" fuel is required to be 15 ppm. Some "off road" fuel is still 500 ppm or a blend of 500 and 15 ppm. As of Jan 1, 2010, ALL diesel fuel will be 15 ppm and the only difference in any "on road" versus "off road" fuel will be the red dye, which is added at the distributor. This is straight from two competing local distributors. Two years ago, I had to specify that I needed ULSD 15 ppm "off road" red fuel for my customer's 14 diesel forklifts. Then, it was "specific" for them, where the distributor added red dye to otherwise "on road" fuel and sold it without the road tax. Now, all his fuel comes in ULDS 15 ppm and the dye is added to all off road fuel. All the same fuel, just with added dye to identify no road tax.
As for your DPF, you could LEGALLY disable it, as your vehicle is being used exclusively off road. If you are getting 500 ppm fuel, you will clog/ruin the DPF anyway. Same thing will happen if my customer were to run 500 ppm fuel in his lifts, equipped with optional catalytic exhaust systems, for indoor use. It specifies 15 ppm max.
