DPF / Extended Contract Issue
half ton diesel - why?
EPA vs Edge products
I have read up on the numerous DPF issues plaguing the 6. 7L. As a new owner I to have been bit by this bug. So I need some advice/direction on my situation.
I have a 08 6. 7L 2500 4x4 Quad cab. It was purchased used by me at 53,000 miles from a Chevy dealer in Newberg Oregon. I also purchased on the side a Chrysler LLC extended contract (Pre Owned Maximum Care 5/70). Everything is running fine and I have put less than 1000 miles on the vehicle.
Last weekend while freeway driving I get a check engine light. I took the truck into a Dodge dealer in Newberg to check it out. The dealer determined that the DPF filter is clogged and needs to be cleaned/cleared. We get a call back later that they can not fix it do to another dealer in Salem, Oregon was worked on it 4 times in the last 3000 miles for the same issue, and Chrysler has already paid to have the work done.
So now my Newberg dealer doesn't want to work on it cause they wont get paid for the service. Newberg says take the truck to Salem and have them work it as a "workmanship" issue. Well to me that is a hour drive away and inconvenient. If one dealer has worked on it 4 times and did not fix it that would be insanity (legal context) to me. Taking it there a 5th time and expecting a different result.
One of the requirements to get the Chrysler extended contract was to have a Dodge dealer "inspect" the truck for issues. Newberg performed the inspection and passed it with no issues. So I had no prior knowledge of the Salem work being done, and it was done prior to my ownership, and prior to my service contract. Now Chrysler wont cover the work for the DPF issue. To me it should be covered since I passed the "inspection".
So to me my options are this.
1. Pay for work out of my pocket to Newberg.
2. Take back to Salem and hopefully they will honor their craftmanship and cover the cost.
3. Fight Chrysler to pay for it again (Seek legal counsel?).
4. Go for DPF delete and void my entire warranty and through $2k down the drain.
Thoughts? and thanks
I think you're going to be forced to return it to the dealer who previously worked on it.
If so, you should sit down with the service manager and review the service and repair history to build a better understanding of what has been wrong with the truck.
You might try communicating with your Ram district service manager for advice and assistance.
I have a vague memory of a fellow TDR member who lived in OR who had a very similar truck if not the same one. He found the truck incompatible with his lifestyle and driving style because his duty cycle involved slow speeds and short trips. After repeated emissions problems he traded the truck for a Ram 1500 iirc. This would have been as much as two years ago.
i Had a similar issue. i held my ground and told them to call the district dodge rep. Although we never spoke, half a day later the replaced my entire rear axle under warranty (vs demanding over $3k out of pocket) the worn axle tube was due to a different dealer not properly fixing the seal on the axle.
(spun the bearing on the tube, it had flat spots on top and bottom of axle tube, and would click when i went around curves-i would have sworn it was the frt u joint!)
On a different note it almost seems like you got someone else's lemon vehicle! I would take your vin to a dealer to see what work has been done to it, if a lot, (same exact parts/problem) i would try to return to purchase place as some type of lemon.
With dmv you might be able to get ahold of original buyer to get the truth.
So I picked up the truck today from Newberg. The adjusted the regen thresold and told me to drive it over the weekend and maybe it will burn out. If the problem continues then to bring it back on Monday and they will replace the EGR valve.
We looked at the history Salem performed on the truck. In less than 150 miles 3 different diesel mechanics at Salem replaced the DPF twice and the turbo charger. Per Newberg they did not follow the troubleshooting mapping. So we will see what happens with Newberg.
Grab the popcorn and stay tuned next week.
Hmmmmm. I wonder how that mechanic accessed and modified the ECM programming. Sounds like bs to me.
It sounds like you may have got an Oregon lemon law truck. Dodge dealer bought the truck back, then took the truck to auction, the chev dealer bought it and sold it to you. Like said, I would go to Oregon DMV and get the last owners name and find out for sure what is going on with the truck. If the truck was not TAGGED in the Dodge computer they will have to honor the warranty.
DMV giving out a name would be a privacy law violation . call the 800 number in your owners manual,they will help resolve your issue
sounds like a lemon law issue. contact an attorney, usually the first visit is free….
if the warranty won't be honored, due to a different dealer worked on it.
the vehicle was sold with a known problem…(vehicle history). .
newburg dealer won't work on it.
the vehicle can be deemed a lemon.
forced buyback…. and refund of your money. .
if you had a trade and they already sold it, they have to reimburse you your down payment as well. (not what they got from your trade). .
good luck. .
good luck. .
I doubt any state has a lemon law on used vehicles. In California there must be 3 failed repair attempts on the same issue or over 30 days in the shop.
good luck. .
Well we now all know why the previous owner traded it in, I would take it back the the Chevy Dealer ASAP, then contact your local DMV office, I think you have a truck I would not care to be involved with, best of luck.
Not in Oregon you just go fill out a form and pay a few bucks. DMV records are Public Informatiom.
Sounds like you got a raw deal. My truck I bought used at 42K, now at 126K, I just drive the pee out of it and it runs great. The DPF did take early retirement, but I keep it in the closet if I ever trade it in.
Sounds like the dealer isn't resolving the core issue: defective/broken EGR. I had a similar experience with my prior 2008 CTD; turbo and DPF would clog every few hundred miles. It turned out the EGR was broken and regen was never occurring.
