2nd Gen Non-Engine/Transmission drag link questions
Engine/Transmission (1994 - 1998) Part Number
my drag link ends are very bad. can they be replaced independent of the rod, or do i get a whole new drag link... if so what replacement part should i get?
also doing tie rod ends... what brand is recommended here?
Looking for something heavier duty than stock. any thoughts would be great!
You could also add a Lukes link to them and then as they wear, you can adjust them. I think I'm gonna do this to my pass. side tierod end so I can avoid haveing to pay for another front end alignment when I'm done.
If you want "the good stuff" go with MOOG, It seems that every one I have talked to prefer Lukes link as a #1 choice but as far as replacement joints go MOOG is the only way to go, they use brass liners in their joints and almost every one else uses plastic, which is why they wear out so fast.
