Draining water from the Fuel Filter
MPG for the record
Need to replace ATF/coolant heat exchanger
OK I give up. I've seen the other thread on draining the water out of the fuel filter but you should not need to loosen, remove or whatever, to simply drain off some fuel to check for water in the fuel filter. Sure, the owner's manual says lift the valve and lower the valve, and... . isn't something supposed to happen!! As a number of you have said "nothing comes out when you lift the valve lever. " Well, same here. So what gives? There must be some method of performing this task without tools, gloves, taking a bath in fuel or spilling fuel down the side of the Cummins or front suspension? #ad
White 2001, 3500, Auto,3:54,QC,2WD,LB,34' DBL slide Cardinal 5er
Tag, Not sure if this will work or not for I haven't done it yet. My thought is next time I remove the filter I'd like to install a quick drain (like the small airplanes have)so I can "waste" a little fuel via way of a tube to the ground. You can always catch the fuel in a glass to see if water is present as well. Just a thought, but worth the effort if it can be done in my opinion.
P. S. Buy your fuel from a station that sells a lot of diesel to avoid problems with water and keep the tank full if don't use your truck much. Water formulates fast in containers which are only half full. Or is that half empty...
Dave
If I simply lift the lever up, I get no flow. If I lift it up then close it a little and then back up it starts to flow.
Try it.
Big-D and Mac thanks for the suggestions. I'll try Mac's first and see how that works.
If Mac's idea does not work, just loosen the fuel filter lid to break the seal. It should then flow.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro and boost and engine oil temp. gauges,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat,Edge EZ box and blow by bottle is bye bye !!!
My Truck
Tagalong,
I agree, you should not have to use tools or disassemble your truck to drain water from the fuel. Mine also will not pump the first time I lift the lever. I usually work the lever about 4-5 times before I get a really good flow.
Hope it works for you.
Merry Christmas to all.
David
'00 2500QC 2WD 6sp. loaded with all but leather and cab lights.
I do the same as Mac and it works if I open the valve and close it and then reopen it again and it works every time or atleast on my truck.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, 4w ABS, camper and trailer tow packages, HD transfer case, snow plow prep, group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, 4" JRE exhaust, BD exhaust brake. 22500 miles as of 11/11/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
[This message has been edited by Douglas Hatfield (edited 12-29-2000). ]
Dont loosen the lid,the reason it wont come out is because it is not vented. There is a shraeder valve on the fuel line right behind the filter,with the drain open just insert fingernail in shraeder and it will drain all you want.
Terry,with your method doesn't air get drawn into the system that needs to be bleed or else the engine runs poorly for a while?On my 12 valves if nothing comes out I just push the manual pump button on the lift pump a few times.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
Just my two cents worth. I had the dealer show me what to do to get the fuel to flow and you guys are right. You have to work the lever up and down a few times to get a good flow of fuel. The dealer says this is a normal function.
2001 2500 QC 155" WB 4X2 Flame Red Clear Coat SLT Laramie Mist grey interior Trailer Tow group Camper special group Travel convenience group rear slider power seat fog lamps keyless entry AM/FM/CASSETTE/CD W/6-INFINITY SPEAKER SYS LT265/75R16E added stainless wheel well eyebrow trim stainless exhaust cover brushed alluminum RAM billet over cab light Delta Diamond Plate 5th wheel tool box, Dee Zee diamond plate bed rail caps and stainless steel running boards. To come is Line X sprayon bed liner. Also looking for anyone intrested in forming a chapter in and around the Chico, Ca. area?
You can do one of two things... .
open and close the lever to sort of start pumping out the fuel. This should cause a stream of fuel to flow. -OR-
Open the drain lever,then remove the black cap on the pressure test port where the fuel line goes into the injector pump and push open the shrader-valve with your fingernail. This will also cause a stream to flow.
I have found both ways to work for me.
-Mike
