I have one on my truck as well, love it. It's an easy bolt up affair - UNLESS the idiot at the factory cross threaded one of the bolts! One of the bolts holding the sway bar to the frame was cross threaded on mine and it was a NIGHTMARE getting it out.
Thomas, why would you need the tow hooks with the hitch? I have a clevis that I slide into my front hitch to use for recovery, I went with the front hitch specifically for that reason. with the hitch you're pulling on both frame rails rather than just on one.
Vic, I have heard of some guys running both a brush guard and the front receiver - but in some cases the brush guard will need to be modified slightly. The receiver attaches to the lower bumper bolt on both side on the outside of the frame, I believe that's where many of the brush guards attach as well. If so, then you'd have to spread the mount slightly on the brush guard so it goes over the hitch mounts.
