dreaded hvac problems
Static Shock makes instrument panel light up?
Blend Doors
need a good service dept in the mobile alabama area. just don't have the time or energy to start a project. somtimes i hate that there is a dodge wrapped around my cummins diesel.
Poor design is the real problem with these ac and heat boxes under the dash.
I am ready to take a sawsall to the dash and build my own ac/heater box out of plywood:p
It could be no worse than the plastic mess that dodge has under there.
Amen on the sub-standard heater unit. I have thought about adding a Red Dot 2-fan heater under the front seat blowing forward to keep my feet warm. Used to do it in the old Cabover Freightliners and it helped a lot. :-laf
You don't realize how poor a design it is until you ride in a GMC or a Ford and have to turn the heat DOWN after 10 minutes or so because you are too hot in the winter. Oo.
