I drilled the stock manifold using a shop vac, grease and went in with q-tips to get any leftover stuff when done. Now when I start if up it sounds like a marble is hitting the fan of the turbo during idle. I ran it for maybe 2 seconds and then another 3 - 4 seconds to confirm what I was hearing.
Q: Should I
1 - hit the go pedal in hopes to blow out the left over shaving? (don't think so)
2 - Pull the turbo down and clean out
3 - Let idle for a minute or so
4 - Pull exhaust down and try to clean from back end.
Any help would be APPRECIATED!!!!!
Signed - depressed Cummins owner :{
Q: Should I
