Well, that is a severely qualified answer. They only exist as modified parts. Not as factory supplied stock parts.
Not sure I agree with the comment that was made concerning "unsprung weight".
The amount of material removed by drilling holes in the drums is going to be an extremely small percentage of the total drum/wheel/tire/axle weight.
In practice the ride quality of the vehicle isn't going to change.
If you drill your own drums, I would just caution that you make sure to keep all holes matched side to side and have one opposite the hole being drilled to keep the dynamic balance forces in check.
Luck to you,
John
