A while back I installed a gauge to check drive pressure. I found that while it was ok up to around 50 psi of boost(55psi drive), above that it went up quickly. At 60psi of boost, drive was in the 75 to 80psi range. I have since switched secondary chargers and my drive pressure at 60psi boost has gone to 55 psi. Am I less likely to blow a head gasket at say 65/65(boost/drive) than 60/75? Or does the drive pressure not really matter as far as the gasket is concerned?
