Drive pressure guage install
Why is no one using a Fuel Pressure REGULATOR??
Propane for 7.3L equipped Ford
Hello all.
Have you done the pre-turbo guage? Wondering "how to" on the fittings & type of hose. No doubt hi temps happening there. How did you & what did you use?
I've gotta find a Boost guage somewhere too. Someone has got to have one laying around. :)
tia
Forrest
i drilled/tapped a 1/8" npt hole in the side of my manifold that didn't have the egt probe. then, just an 1/8" compression fitting to copper tubing with a couple coils (heat dissipation), behind the engine, 1/8" compression fitting to hose barb, about 3" of rubber hose (noise suppression, before i did that i had a nasty click at the firewall), hose barb to bulkhead (through the firewall), plastic line to gauge. been running like that for a while with no problems. except now having the knowledge that i was REALLY working my turbo before i put it in. check "old smoky"'s readers rigs for a good pic at the manifold.
dave
Forrest.
I just put one on my truck, I could have shown you at the dyno event. Consider a larger size, 1/8" gets clogged, or so i am told.
Ron
Thanks everyone.
Dave ... i just looked up old smokys ... here it is ... thanks.
Ron ... i gotta see your "fuel pre-heater". :-laf
