Might want to try a wastegate.
i've got one. just an old actuator that i cut the housing off of. kind of like a ghetto turbomaster now. still messing with it to get it figured out. if i cinch it down, i see over 40psi. oh yeah, i've got the wg port drilled out to 15/16 (from the stock 5/8) all the way through the divider.
or drill and tap another hole, and install a boost fitting.
thats what i did. and ran copper tubing all the to the gauge
(a very restrictive exhaust system can cause problems too).
don't have one of those
and the mass of the turbo rotating assembly.
sooo, a bigger turbo affects the drive pressure in what way?
cerberusiam, why wouldn't the oil pressure gauge work? i would think that it's the same thing, no?
I have a drive pressure gauge that I watch every day to tune my compound turbos
i'm thinking that i will make this a permanent addition to my growing "array". so i can tune my non-compound turbo.
dave
