Engine/Transmission (1994 - 1998) drive ratio ?
Engine/Transmission (1998.5 - 2002) Shop Vac Filter for 02 cummins
does anybody know what the final drive ratio is on a 4x4 47RH in drive ?
and what is the Tcase ? 2. 72 is that in high range or is it different in low range?
Those are the ratios for the transmission. The 2. 72:1 that you posted, is the ratio of the low range of the t-case. High range in the t-case is 1:1.
do you know the calculation to find your final drive ratio,Ibeleive I need to some how figure the tire size,axle ratio,trans ratio.
I am trying to figure out what I am runnin now and then again with new gearing.
Rod, I have a spread sheed at work that I will send you, enter tire size, rear end ratio and it calculates the wheel speed in 1stlow, 2ndlow, 3rd low, then give you 3rd high and ODHi, for 2500-4500 RPM.
Drive low range, is 2. 72 x your rear end ratio, then figure out your tire circumference in miles(lol), then convert engine RPM, to RPH(hour), and then go!
