drive shaft bolts torque spec.
High RPM fuel.....with electronics..
is my truck an 03 or 05?
I changed the rear u-joint in my buddys 03 today and what a nightmare it was. Finally, on the third attempt, we found one that would work. All that aside, can someone supply me with the torque spec for the four bolts on the pinion end of the driveshaft? I am going to re-check them Sunday morning. I cleaned both flange faces, cleaned the threads, used (blue) loctite, and snugged them up real well using a half inch long handle ratchet in the cross-pattern. Did I miss anything other than the torque spec?
Thanks, Jim
you will be ok with doing that...
service manual said:
PROPELLER SHAFT
TORQUE SPECIFICATIONS
DESCRIPTION - Ft. Lbs.
Center Bearing Bolts - 40
Transfer Case Flange Bolts - 65
LD - Front Pinion Flange Bolts - 85
HD - Front Pinion Flange Bolts - 21
Rear Pinion Flange Bolts - 85
Rear Pinion Yoke Bolts - 22
