My problem is there is play in the driveshaft. Its rotational, meaning when I shift into drive or reverse, the 'slack' is taken up pretty harshly and it appears to be getting worse. I assume that means that whatever is worn is getting worse and I need to get it fixed before it blows apart.
I really can't tell whether its in the transfer case or in the rear diff. Whats most common? What should I hope it is?
By getting under the truck and rotating the shaft by hand, it probably goes between 1/4 and 3/8 inch both ways. I sense there is more play at the transfer case than the rear end if that is possible.
Both U-joints are good and there is no play there at all. So much for an easy fix.
HELP!! Where to start? I really don't want to have the truck down for a long time. Any past tricks to make the repair or replacement easier?
Thanks... .
Thanks... .
