Please help. 2006 Quad Cab, Longhorn, long box, G56 Transmission, 4WD, 373 gears, 88K miles, totally stock. Truck would vibrate decelerating and shudder horribly stopping. Carrier bearing bad. I see Andy Redmond in TDR issue 86 replaced a 2 piece drive shaft (which my truck has) with one piece. Would this be a good solution for the long haul for me with the QC/LB, or should I just replace the carrier bearing? Would a one piece drive shaft be compatible? I tried a search for "drive shaft", but was not returned with any posts. Also having a bit of difficulty coming up with the correct replacement drive shaft. Thank you
