Engine/Transmission (1998.5 - 2002) Driveline grumble on de-celeration
Engine/Transmission (1998.5 - 2002) What the smoke?
2nd Gen Non-Engine/Transmission Describing the Steering Symptoms
I've started noticing a slight "grumbling" when coasting on the highway. It seems to happen when the driveline is right at the "neutral" point meaning it is not accelerating or decelerating. There seems to be more driveline slack also.
What should I look for.
Thanks in advance.
John
u-joints in the read driveshaft. mine did the same thing. no load on the joints allows them to move around in their bores if they are a bit worn. climb underneath and twist the driveshaft by hand (PARKING BRAKE ON, WHEEL CHOCKS, BE SAFE!!!) to see if there is any play in the u-joints.
