Engine/Transmission (1998.5 - 2002) Driveline vibration
2nd Gen Non-Engine/Transmission 4x4 troubles
Engine/Transmission (1998.5 - 2002) ATS intake with rusted bolts!
Trying to find out what is causing a vibration at takeoff. It is more noticeable up a slight slope. Only does it around 20 mph. All other speeds is fine. Just installed new Georend trans. Was doing this before trans. Fluid in transfer case is good. U-joints dont seem to be making any noise. U-joint cap bolts are tight. Is the transfer case on the way out or drive shaft out of balance? Any advice would be great!#@$%!
01 qc,4wd,gauges,Comp,Georend w/billet input,triple disk,S&B,4" turbo back,Super B single,BD manifold,FS2500,Airdog,Bilsteins,level kit,FBD150's on order.
Do you have a two pice drive shaft?
_________________________
93 250 2wd xc 373 auto 271k
04. 5 3500 4wd qc dully 373 6speed 94k
Sounds like limited slip clutch chatter symptoms. Also check your motor and trans mounts for looseness and/or rotted rubber.
Put the rear up on jack stands and spin the rear tires. Look closely at that drive shaft. It only takes the littles bend to be a problem. We just replaced a shaft in a 08 that the dealership said was fine, he bent it at the dump. Also I dont know how long it had been scene your trany work but you might pull the shaft and check the u-joints to see if one is freezing up. look to see if you lost a wheel weight or a tire has a bulge on it. I would check the cheep stuff first. Good luck.
