Driver sied rattle under dash driving me and my dealer crazy!
Camper battery charging wire
air conditioner specs.. HELP!!!
I thought just maybe someone else out here has had this same problem. I'm getting a rattle under driver side dash that almost sounds like an electrical connecter banging on something. Will be more prominent at times. More noticleable at slower speeds . Dealer has had it for 2 days now and still can't find it. I did notice a rattle on engine shutdown, but the dealer says that's a different rattle! My dealer and me sure would appreciate any tips!
KEVIN O
JUST RECEIVED... ... ... ...
2001 2500 ETH DEE, QUAD CAB, SLT+, ANTI SPIN DIFF, CAMPER AND TRAILER GROUP, SLIDING WINDOW, BLACK CLEAR COAT W/AGATE LEATHER, BRUSHED BLACK ALUM SIDESTEPS, BEDLINER, JACOBS EXAUST BRAKE AND THAT VERY SPECIAL FRONT AIR DAM!
OH YEA, 3. 55 REAR END--SHORT BED--4X2--TRAILER TOW MIRRORS--SOFT BED COVER--34FT. 2000 NEW EAGLE/JAYCO FIVER--15K REECE HITCH
One thought, your brake controller(assuming you have one) plugs in under that area or the dash. Is the connector or associated brake controller wires making the noise? Might be worth checking.
I also have an intermittent rattle in that area, but I don't trust the dealer to explore my dash. I figure they will blame it on my gauge and/or controller wires anyway!
99'2500 SLT QC LB 4x4
white/agate, 5spd, trailer, camper, 3. 55LSD, 241HD, cab lights, 3500 tailgate lights, mopar mud flaps, luverne SS nerfs, diamond plate rails, Weatherguard box, Banks 4inch, Isspro Boost/EGT gauges(pre), 265 BFG KO's, ... more to come
Dealer found rattle! Located in inner fender underneath hood. lubed and adjusted. All fixed---no other squeaks or anything. I was worried about them butchering up my dash---but everything is ok.
KEVIN O
There is more on this. Just do a search using the search button at the top of the page and you can get everything that has been talk about this topic.
Good luck!
Mine is a squeaky, birdie kind of a thing in the same location. Drives me nutz. 11,500 miles.
2001 2500 QC, ETH/DEE,4:10s, LSD, VA Magic Box, Boost/Pyro Guages, 4" Turbo back, BD Brake, 20K Reese. (RV Dealer)
Try lubricating the small (1 1/4" dia. x 3" long) coil spring on the steering shaft against the firewall in the engine compartment. use white lithium grease every other oil change. Our 98. 5' and 01' both chirp if it gets dry.
Ghostroller is right. I found out how to stop it when changing the fuel filter and spilled some #2 on the steering shaft. I had a chirping/squeak when cornering on my 98.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, EGT/Boost Gauges, Running Boards, K&N,
Real Backup Lights
Kevin,
My truck is 1996 model and makes a noise to what you are describing. I got as far as I could get in taking the dash off, but could only get so far with that because I do not have a manual. Anyway I can grab the spring on the steering shaft that comes right out of the fire wall and move it around and the noise will go away. The noise stays gone longer in the summer time than in the winter. Where about in the inner fender welldid the dealer locate the noise? Glad they were able to find the noise. I have been to two different dealerships with no luck.
96 3/4 CC 5-speed,4x4,
anti-spin,tow,camper,3:54
B&W Turnover Goose Ball GY305r70 on Aluminum
Wheels
Brown MFG Heavy duty Front Bumper and I do mean Heavy Duty
ROG,
I will call the dealer sometime today to see where in the fender well area they found it. I've been off camping for the last few days and haven't been around. The truck pulled great though and that rattle seems gone!
KEVIN O
