I have an 04 2500 with nv5600.
I replaced my hydro booster & master cylinder.
Yes I did bench bleed the mc before installing.
Since then my driver side only caliper engages / locks up daily. If I open the bleeder screw it relives the pressure for about 24 hours. And then the issue comes back.
I shot the parts cannon at it. I've replaced the caliper, the rubber flex brake hose (oem) and the steel brake line that connects to the rubber line and runs up to that silver block next to the battery. I've also replaced the two brake lines that run off the mc to the silver box of lines next to the battery.
I don't know what to do at this point... is it something with the master cylinder?
