Drivers side negative cable
Tires/rims wanted
Does anyone know the correct part number for the drivers side negative cable on the 2007.5? Dealers websites show 2 and 3 different cables with different prices. I went to clean my terminals (positive had lots of corrosion) and saw that the negative terminal was cracked almost all the way thru.
If you want to be save then give the VIN to stevewhite and say which cable you want, you'll get exact the right part.
I prefer the military style terminals. Cut off the old terminal and solder on an eyelet style end and replace the batt terminal with military style. They have studs on 2 sides for extra electrical cable connections and are much more robust.
