I have a 2000 Ram 4x4 Quadcab Short bed having a problem with the driver’s side window.
It has always gone down normal, still goes down normal; the problem is trying to get the window back up.
It started out that the window wouldn’t go back up if I used the ‘auto down’ portion of the switch, you had to wait a few minutes then it would come up. If I stopped it right before it was all the way down (on 'auto down') the window would go back up fine.
Next it started only going up half way regardless of whether the 'auto down' was used or not, and then I would have to wait a few minutes before it would go the rest of the way up.
Now it will only go up ~ ½" - ¼” at a time and you have to wait about 4-5 minutes before it will move again at all. Not good when it's raining out!
No problem with the pax window with either side control, or the door locks.
Any idea what the problem is? Maybe the relay?
Thanks in advance for any help!
TSmith
TSmith
