GrantP
At 150k I've developed a minor driveshaft vibration at 55 mph, the u-joints are all original. I'm pretty sure the u-joints are dried up based on the fact that I just had to replace a bone dry front axle u-joint. I've already purchased replacement u-joints and a carrier bearing (should arrive in a few days). My question is regarding the removal of the carrier bearing from the driveshaft. The factory manual says to use an OTC 1130 bearing splitter which costs more than all of the replacement parts did! Has anyone had any success driving the bearing off/on with a soft punch or is the puller a necessity? I've never had a truck with a 2 piece driveshaft prior to this one so I've never replaced a carrier bearing before. The carrier bearing may not even be bad yet, but while I'm "in there" it's going to get replaced too. I'm going to dive into the replacement this weekend and I'm just looking for some advice from others who've had to replace the carrier bearing... thanks.
