Engine/Transmission (1994 - 1998) Driveshaft carrier bearing
Engine/Transmission (1994 - 1998) Finding fuel leaks
2nd Gen Non-Engine/Transmission Dash panel\A Pillar squeek fix !!
Does anyone know of a good place in SE Michigan that I can get the carrier bearing replaced, OR is it too hard to do yourself? I don't have a press. What is involved in chaning it?
Any help would be great.
On my 96 3500 2WD, it is pressed onto the driveshaft. Any competent heavy duty driveshaft repair shop should beable to make this repair in an afternoon.
Find a Dana Spicer shop - should be plenty in SE Michigan.
(Off course Dodge had to make a non standard bearing specific to the Dodge instead of using an off the shelf carrier bearing)
Check with your local auto parts stores. If they have a machine shop they can do it.
Pressing on a bearing is one way of doing it. The other way is to heat the inner race up for about 30 seconds with a propane torch. Then it will drop into place without force. The bearings rides against a step ledge. So you won't go past where it belongs.
A lot of mfg's use this method to install bearings. Less chance for something going wrong from the brute force of a press. Plus it is faster also.
I always had a cutting torch around. Cut the outer race and ball cage, then heat the inner race. If that isn't enough, lay it on an anvil, heat a red spot on the race and smack the hot spot with a BFH! Redram, doesn't the bearing have a number that a bearing store can cross over? That must be why they're so expensive. Craig
I'll have to dig through my box of old parts to find the number.
It was a non standard bearing having that step flange as pointed out above. How's the hopped up truck Craig?
Mine failed several years ago and could not find a bearing easily. finally found a Dana Spicer Driveline shop that was able to order one from Dallas.
I would imagine that this bearing is now a more commonly stocked item. I would recommend looking outside of the DC dealers as their price was quite high, several hundred dollars and it still had to be installed. I seem to remember I got a new bearing, rubber doughnut and installation for less than 100.
If you're having trouble finding a replacement, I believe that I could find the part number if needed.
