I have a possible problem, so bare with me while I describe it. In the lower gears while accelerating lightly I have a slight nudge like there is some slack being taken up somewhere in the drivetrain. There is no noise, metalic clang or thud associated with it. I have checked all transmission and motor mounts, and even the transmission to transfercase bolts to see if there was something loose after the instalation of my South Bend Clutch.
When it happeds it is like a slight nudge that can be felt in your lower back. The transfer case lever jerks forward about . 5 inches and the gear shift jerks back about . 5 inches with constant light throttle. It is like there is a detent being engaged. That is the best way I can describe it without giving you a ride in the truck. is it possible that there is a broken spring in the clutch hub? or is the new clutch just making this "normal" occurance appear abnormal?
TIA
_cliff
TIA
_cliff
