I'll will be moving back to my home town of Paris, TN from Yakima, WA here in about 2mo. I believe it is roughly 2200-2500mi. I have a few questions as to what I should to ensure a breakdown free trip. I've owned the truck since June of last year w/ 207k miles on it and have put on 18k and the only thang I've had to replace is the battery. Thangs I know I should replace are the serpinteen belt, the lift pump, and most definately the tires (fronts are bald
). I would also like to get the Borgeson steering shaft, 4" exhaust, and 16cm2 housing while I'm close to Piers and Stan's. Now, my fuel gauge hasn't worked since day one and I was wondering if I could just replace the whole unit inside the tank to solve the problem. I figure the gauge is still good because some times it will read just not accurate. If yall can thank of anythang else that I should do before I go I'd appreciate I. One more thang which isn't somethang I'm worried about for the trip but sometimes when I start my truck the blinkers, lights, windows, and radio won't work. I can shut I off and crank it back up and everythang works fine. My dad has the same occasional problem on his '96 except its just his drivers side window. Thanks for the help.
