A while back I installed a leveling kit and developed a clunking/knocking noise. I could feel it on the driver side floor board. I took it to the dealer and they replaced the driver side tie rod and the bar that runs from left to right( with the hole in it where the steering stabilizer bolts to). Noise continued, took it back to dealer, they then found the bolt that bolts the upper control arm to the axle was put in backwards and was hitting the frame when turning and the axle was pivoting. Fixed that and noise was gone. Well guess what, noise is back. Checked everything under the front end and found the end link bushing were worn so I replaced them and noise isn't quit as bad but still there. Any suggestions would be greatly appreciated. Thanks in advance.
