Adding driving lights to Canadian trucks makes wiring interesting! I have spliced into the high beam wire to run additional driving lights. To my frustration I have found that the DRLM (Daytime Running Light Module) uses the high beam at reduced volts. The voltage is high enough to pull in the relay and power the driving lights. I have unintentionally had the driving lights on in the daytime with my headlights off. I have been informed by truckers most unceremoniously of my error! The only other way that I can think of is to use the high beam indicator light on the instrument panel. The interesting thing here is that there are 12 volts to the indicator light when the high beams are off (DRL and low beam), and 0 volts on high beam. This power comes from the DRLM. I can use a relay with the 87 or 87a output and use the side when power to the relay is off. Or is there an easier way?
I also want to run heavier wires to the Dodge headlamps. How can I wire this and still use the DRL?
Any solutions are welcome.
Thanks.
Stan
Thanks.
Stan
