Drone with Huspower
Hard Starting
Had the dealer ecm reflash today
Hi to everybody.
Over the weekend I installed on my 2007 Hushpower cat back system. Installation was easy and fit was top notch. I bought this system after reading the article in Diesel power or maybe Diesel World magazine, where they stated is a drone free. But my problem is that between 2000 - 2500 RPM drone is so big it is almost unbearable. I like to have better freeflowing exhaust, but decide not to put one on my 2007, because of the drone problem I had on my 2001, but somehow this article change my mind. Bad move. Is there any other muffler which will help with drone ?
I would go back to stock one, but only way to get OEM muffler out was to cut flanges and can't be use anymore. I find this on the site which sell Aeroturbine. Anybody have any experience with it ?
Aeroturbine Performance Muffler With Exhaust Guide Combo Increases Fuel Mileage and Performance
or just add this to Huspower.
Aeroturbine Performance Muffler Increase Fuel Mileage and Performance
thx Milos
The Aeroturbine doesn't do a lot in terms of noise reduction, I doubt it will make a major difference with your drone issue.
Past remedies were to wrap the downpipe with header wrap, also clamp a length of angle iron 2-3' long to the pipe leading off the downpipe.
I had pretty bad drone issues with a Banks Monster Exhaust in my '03. I ended up adding a MBRP 30" muffler where the cat would go on a newer truck. It killed most of the drone. The Aeroturbine mounted in the same place is also supposed to kill the drone.
Currently I have a Donaldson M090535 51" muffler (5" diameter pipe) plumbed into the stock 4" system. It's supposed to be drone-free as well, but I would argue otherwise when I have 10k hooked up and going up any kind of grade.
In my experience I have found that changing how far your tips stick out from the bed changes the amount of drone on my '03. I pulled the tip off and cut the pipe back 6" and it reduced the drone quite a bit. I haven't wanted to change the stock looking pipe on my current truck, so I'm considering a change to an Aeroturbine 5050XL. I like the deep tone of a 5" muffler, but I don't like it loud.
Good luck!
i had the same problem with hushpower muffler. the drone was so bad i went back to stock. i emailed hushpower and told them their ad for no drone was false advertising. no reply from them. $200 down the drain. they have no customer support.
Yeah, I email them monday, but so far nobody write me back. I will probably go back to stock, but problem is I made damage to the muffler in removal process.
Which bring another Q. any place on web to purchase new OEM muffler ?
I don't want to pay dealer premium for it.
THX milos
I would like to upgrade to a high performance exhaust system, but sound and drone is a problem. What is the answer or the best answer?
I Have Silent Might it is a straight thought muffler
and has some holes at the end I think it is
as quite if not quieter than stock and
no drone even pulling a 32' trailer I have it
from cat back
Home
Joe
I hate it when that happens. I went through a few changes on my 03 due to the drone and when I bought my 05 I have held off making a change cuz I like quiet.
Now that I tow more heavy I will make a change soon. Still wanting quiet with better flow I will go with a Donaldson M100580
If you look at the Attenuation for low sound and it's flow numbers, I challenge anyone to find something better cuz I would want to know about it.
It's 5" in and out so adapters will be needed.
from cat back
Home
Joe
I hear good think about this muffler, but look like they don't sell them anymore.
m:cool:
you took Flowmaster's word that their muffler didn't drone!? :eek:
if you want a good muffler, get a 51" Donaldson.
also, the BIGGEST help for cutting interior resonance is sound deadener (Dynamat type)
i got my diesel power mag in the mail today and i noticed that hushpower did'nt advertise this month. they have been untill this month. maybe words getting out on their false claims. i hope so.
i have an 05 with banks cat back big time drone towing. spent like 40 bucks at muffler shop for a section of 4" tubing and 10 bucksat napa for an band style clamp. cut out cat installed new pipe. no drone what so ever sounds good too. a little deeeper tone ouy tip. good luck.
I am surprise you cut the drone by eliminating cat convertor. I was basically hoping cat will help to not have drones.
I would probably end up to put OEM muffler back. Somehow I am surprise what kind of garbage product the exhaust manufactures sell us.
milos
i have an 06 with no kitty and the drone was so bad with a hushpower muffler i went back to stock. so much for false advertising for no drone with a hushpower muffler. $200 down the drain. emailed them last week and still no response. i won't hold my breath for a response!
im happy with the banks exaust with no cat. i did keep my cat just incase i have to smog my truck. the truck is farly quite not much louder than stock @ idle. and pretty quite with foot to floor unless you have windows down driving next to a wall or going thrugh a tunnel. id still like my to be a little deeper of a tone. thinking about going to a 5" turbo back magnaflow. 06 Pete with 8" straights and a jake lovly thing in the morn.
