Engine/Transmission (1994 - 1998) Dropped the tank have some???
Engine/Transmission (1998.5 - 2002) Coolant flush....oil
Engine/Transmission (1998.5 - 2002) Tc lockup
Ok I dropped my tank tonight to fix some leaking lines. The lines will be pretty straight forward to fix not to worried about that. It looks like the tank has been dropped before because of the zip ties holding the wireing harness up. They are not stock.
My questions are mostly about the fuel supply lines and the pressure/roll over vavle.
The fuel supply line are pretty rusty and should be replaced. They look like they have some kind of epoxy, may be JB weld on them . So I want to change them. I need the ones that go into the "fuel tank module" in the tank. Were do you get them? Is this a dealer only item? I droped the tank after all the auto parts stores were closed.
Also I need a new nut, gasket, and pressure relief valve for the module.
Im assuming the pressure relief valve is junk cause you could hear air rushing into the tank when you took the cap off.
thanks for any help.
Hmmm I might have those fittings kicking around my garage since I replaced mine with the Vulcan draw straw. Would be willing to send them to you. The only thing is on the inside of the pickup assembly the metal fittins have hard plastic lines connected to them which are practically mission impossible to slide off and onto a new fitting.
thats kinda what im afraid of.
As far as the nut and gasket do i have to go to the dealer or is there a better place to get them?
