'92 W-250 that has been ridden hard and wrecked pretty badly by the previous owner. I recently replaced everything in the rear brakes except the backing plate and the hub. New drums, bearings, slave cylinders, springs, pads, adjusting parts, everything.
The right brake would grab some times and was bad enough that the different level of braking could be felt as the wheel turned which I had attributed to a bad wheel seal but the drum was not only worn out of limits but was worn out of round.
The new installation is doing the same thing while driving. While adjusting the star wheel to set the brakes drag in only evident through about half of the rotation-I believe on the rear shoe-unless I really set the adjustment tight which would be too much-the wheel locks up.
I can't imagine any way the backing plate could be causing it. I guess that one of the new brake drums might have been out of round and the odds are 50-50 that it would go back into the same position...
I pulled the axle out but the asymmetrical drag still existed so it isn't a bent axle...
Anyone have any ideas?
