Whoever designed the guts of the rear drum brakes on these things must have been on ACID!
If he is still alive we should have him Drawn and Quartered!
Did my first drum brake change today, installed new 1 Ton cylinders and flushed system 'til she ran clean like water. . Put in a set of fancy wagner Thermo-Quiets ($$$) and set up the adjusters so there was just a little bit of friction but not much at all.
Off for the test drive. Everything feeling great. Pedal solid. Stops very well. no vibrations, hydraulic system tight, etc. Did about a dozen back-up and slam on the brake drills to get everything "even" with the adjusters.
Get back home and feel drums behind wheels. Driver side hot to touch . . what you'd expect. Passenger side hotter than H***!! Jack rig up again at 11:30 PM to see what kind of drag on wheels. Passenger side just solid locked-up!! :{ Driver side a little bit of drag but not much.
WHAT IS GOING ON!! I need help on this. My spirit is flagging after all that gut busting work in 90 Deg. heat with heavy humidity and now I have to deal with this! Give a guy a break!!
Any Brake GURUs please jump in.
