Time to replace my rotted parking brake backing plates on my '04 DRW which requires pulling the axle to remove the floating hubs. My garage is somewhat tight and the last 2X I had the axles out I turned the truck around in the middle of the job.... a PITA. This time I want to (hopefully) position the truck so I can do both sides without moving, does anyone know the axle shaft length so I can measure from my hub flange to the wall instead of guessing?
