Archived DSRB III scanning for problems!!!!
Archived Hard starting &
Archived speedometer/pcm - overclocking
Has anyone had to use the DSRB III scanner for problems and found that that it was, or not able to and that it provided a viris for doing so while down loading the info ?????? Does the palm pilot work for scanning for problems in the ECM/PCM ??? Was told that it didn't and today that it does it is an other 16+ hr drive for more usless info for nothing if this is so :-{} thanks.
Scanner
You have to have a Dedec to read engine codes unless there is a check engine light on or it may tell you to go to service manual for specific codes that the pcm stores. If it stars out with a p1,it is specific to engine and if it starts with p0,it's a pcm code.
