2nd Gen Non-Engine/Transmission Dt Control Arms
2nd Gen Non-Engine/Transmission Speedo Wayy Off??
2nd Gen Non-Engine/Transmission Front wheel ABS Sensor
Who Is Running Dt Profab Control Arms And Are They A Good Product? Any Idea On Cost For A Kit On An 01 As I Cant Seem To Get Them On The Phone. If You Install These Do You Still Have The Adjustment On The End? Thanks Adam
i got them on my 96 they seem alot stronger the poly bushings are alot nicer then stock rubber and i got them 1/2 inch longer to help clear bigger tires the cam bolt adjustment still works the same i belive they were around $300
ken
have them for over two years on my 98. 5, they are in arizonia so call them after 9 am their time. also they are harley riders so they attend alot of bike runs. Mine cost 355 shipped to my door and yes you still have the adjustment at the axle- suggest you get new adjustment bolts and nuts for axle end as they are only one time use types. they will not hold their settings if reused, ask any certified alignment shop.
