DT Track bar to the rescue
Auto transmission and Rear End Fluid Capacity
Auto transmission Shift Points Changed
As some of you know already the DT Track bar is a thumbs up way to go IMO---I installed it this weekend for two reasons--
1) front end clunk when turning
2) because of my lift kit the supplied track bar bracket made the OEM track bar smash into the pumpkin cover upon compression
It made the clunk disappear and I've got a lot more clearance on my Magview pumpkin cover---chris
Track Bar
That's what I need. the problems that I've had with the front end and pulling to the left is because of the drop down bracket so there going to tack weld into place! I think the track bar needs to be replaced. Do you have any pictures you can post? I would love to see it. Thanks
Adam
P. S. Thanks for the info on the rear brakes they were fine
