So, I've been on the road for just under 3 weeks with the bus in my signature, and we've covered about 4300 miles so far with no issues until the other morning. So, here's the list of things that have happened:
Coming into Dallas after driving overnight from New Orleans the bus started losing power on both diesel and veg. It also started idling lower, to the point where it would stall at a stoplight unless I used the hand throttle to kick the idle up. I have new filters on both the diesel and veg systems (along with vacuum gauges), so that's not an issue. Fuel pressure is ok, around 30 psi. I can't get more than about 12 lbs of boost out of it.
On flat ground, it can get up to it's normal cruising speed of about 62 mph, but it has no power pulling hills. Accelerating, it's fine until it hits third gear and about 2000 rpm, and then it hits a complete dead spot.
Last night coming into Houston, the shutdown solenoid let go, so I zip tied it up get to the dealer to get a new one. During the day today, it was starting hard - cranking for a few seconds, then winding way up before coming back to idle. Then this evening after parking it to let it cool before I changed the shutdown solenoid, it wouldn't start at all. I put the new solenoid in and it still wouldn't start. After playing with the throttle link and shutdown link for a minute, it fired instantly and ran fine. I shut it down to tighten things, and then it wouldn't start again until I cracked an injector line, at which point it fired instantly.
My guess is I'm getting air in there someplace, but I don't know where. The diaphragm that controls the amount of fuel delivered based on turbo boost? Like I said before, it runs fine, no smoke, it is just completely gutless all of a sudden.
Ideas?
Ideas?
