It came to me "on the hook". There was enough coolant in the oil that I decided not to try to start it. It was running normally three weeks ago when I serviced it, installed a used ECM (reprogrammed by a dealer tech), and cam sensor. The coolant level was good and it had enough freeze protection. I didn't test the SCA levels. The driver said it ran great with no problems. He was heading back from Atlanta last week and it started white smoking and he got a temp/water alarm. He pulled over and it shut off shortly after. The oil level was well over full and it had some coolant mixed into the oil and more settled to the bottom of the pan. I thought about the oil cooler, but I think if it let go during operation the oil would have gone into the radiator. If I have to go through it to do liner seals or something, I will use a reman oil cooler to cover my behind. It does have a HEUI fuel system and uses brass injector cups. I have been told that if you drop the oil pan and pressurize the cooling system that you will either see coolant coming from/around a liner or from over the cam if it's injector cups.
