dtc code po148
need some help as ware to go next?
04 48re question
New to the 3rd gens,just bought a used 07 a few days ago,now has po148 code,says something about fuel. was going to buy shop manuals but found out the volume is $450. is this a seriuos issue?
no, it is just a fuel deivery err. , if the code is the same for your 07
my truck used to have that one pop up all of the time, my truck is a 04, i just had the cp3 pump replaced for some other problems that i am haveing and the code is not showing up no more.
That last comment at the DTR 40-60psi will destroy the gear pump on the CP3... You should never feed more then 15psi every day use ,competition use 25/30psi. . many things will cause the code,it may be as simple as poor connection to CP3 replacement. the common cause is FCA 1st, 2nd PRV.
I cannot comment at the DTR BC the owner banned Me over 5 years ago. He is a BIG loser (Lary). . and will Ban and censor anyone who's not in harmony with his will.
