Howdy,
2004. 5 2500 Quad-Cab:
Anyone have experience with this code, P0112, Intake air temperature sensor voltage low? I can't clear the code as it is pending and regenerates. I have swapped the sensor from another truck but still get the code. This is the only DTC. I checked the connector at the sensor and have 5v on the proper terminal. I have disconnected the batts and am in the process of reseating the connectors on the ECM.
Thanks, Kevin
Thanks, Kevin
