Dtc p0191 ?
Boost leak test ?
Grinding/Rubbing Sound 1st, 2nd, kinda 3rd
Can anyone tell me exactly what dtc p0191 represents? I've recently had trouble with harder starts and idle fluctuation, also lower power at times. It usually happens within the first 5 mins of running then usually clears up. It would seem to be the FCA from what I have read on other threads. Oil is fine, no fuel contamination. Fuel economy may have dropped a little.
Truck is 05 QC 4x4 nv5600 lwb
Thanks
I don't know about the injectors, I bought the truck from a dealer when it had 237k miles on it so I didn't really have a whole lot of info on the past history of the truck. I have replaced a water pump and tensioner and some u-joints. Otherwise has been a very reliable vehicle. I had guessed somewhere around 300k I would likely have to replace the injectors. Question is would I need to replace tips only or bodies as well?
