Hi,
Recently, my truck's (04 Ram 2500 w/ 5.9L) "check engine" light came on and the reader shows code P2609. I did a search and found the T/S instructions for code P2609, but couldn't find anything related to the symptoms I found... Everything checked out good, but when I measured the relay coil voltage (control signal from ECM) I only read +3.75 volts, referenced to ground, on both (relay #1 and #2) control lines. The T/S instructions have me jumper 12V to the coil to actuate the relays, so I assume that the ECM should supply 12V also? Does this mean I need to replace the ECM?
The truck seems to run ok and I haven't noticed any other problems or codes... Any suggestions?? I've heard that the air heater isn't all that important, since I live in the desert, but don't want to risk getting stranded if something else more important is also failed.
Thanks for any help!
Randy
Randy
