Will a scan tool pick up DTCs that won't display in the odometer window? Or do all DTCs display in the odometer window if they've been set.
Yesterday morning at startup, my Brake and ABS lights stayed on. The "three trips to ON" trick doesn't display any set codes, just the 'P done'. If the scan tool will pick up other DTCs, I'll run by the parts store tonight and have it plugged in. If not, it's troubleshooting time. Any ideas where to begin?
ABS appears to be functioning normally, and braking performance is the same as usual.
JM
JM
