SO i got my new Diesel Performance Trans (DTT) Stainless intake form Stefan (check R&D Forum), and WOW, what a great show of craftsmanship. Installing the intake horn was a SNAP. All you need is two intake gaskets and your gold. The bracket for the dipstick is nice an sturdy as well. On my first drive i could tell the truck had more pickup on accel, i would too if i had to breath threw the stock intake and went to a nice flowing one.
I also at this time wanted to add a 2 micron Fuel filter befor the CP3. so i had the local machine boys make the bracket i designed that mounts to the head, just infront of the intake. i had my first oil Bypass mounted there so i had to move it.
The oil bypass i moved over the exhaust manifold side of the motor. i build up a custom bracket out of some sheet metal. it bolts to the open threaded holes on the cyliner head between the exhaust ports. its angled towards the valve cover at 45 degrees. the Aluminium cylinder you see i had made, so i could have mult ports. the best part is the oil temp sender is smack dab in the middle of the oil flow. i have a oil sample port, and a blocked port for my future oil pressure sender.
I love making things! the wife gets mad that i have to "work" on a new truck.
he he he :-laf:-laf:-laf
