DTT Transmission Installed
Pictures of 3rd gen Snow Performance install?
Edge and smarty
I just had a complete DTT transmission with all the billet steel parts built and installed. James Northrum in Midlothian, TX, an authorized DTT installer, did the work. I have only driven it 1000 miles and haven't towed with it yet but so far am very pleased. The converter is very tight compared to stock. The truck accelerates briskly at light throttle and quickly shifts up through the gears. In first and second gear it feels and sounds like a manual transmission as it accelerates up from stop. No more roaring motor and churning fluid with the loose factory convertor. The transmission holds the lower gears a little longer. Shifts are immediate and firm but don't slam the truck and driveline. The tighter converter requires a little more braking at idle because the converter wants to get the truck moving but it is not excessive or troublesome.
The truck has 135,000 miles on it already. The transmission seemed to be holding up well pulling very heavy trailers until about two weeks ago when I suddenly and simultaneously developed a driveline vibration between 62-68 mph and began losing transmission fluid from the rear extension housing seal.
A dealer in Kingman, AZ "diagnosed" a bad transmission extension housing and driveshaft ($1100 in parts) without even putting the truck up on a lift. I declined and had them install a new rear seal to get me home. After running it low enough on transmission fluid to slip the converter I figured it would have to be rebuilt and decided to have a heavy duty DTT rebuild and hopefully avoid future problems.
When the truck was disassembled I took the driveshaft to a driveline shop for inspection and rebalance. The u-joints and carrier bearing were fine. The shop removed the excess number of factory weights and rebalanced the driveshaft. The vibration is gone now.
There was some debris in the bottom of the pan but not much. I probably didn't actually do much damage running it low on fluid. The problem that caused the vibration and loss of the extension housing seal was the tailshaft bushing that the output shaft rides in was floating free, not in the press-fit location at the rear of the transmission housing where it should have been. The driveshaft yoke had apparently pushed it out of position. Don't know why. It may have been a result of excess driveline misalignment caused by pulling heavy fivers over rough interstate highways and bounding over dips. The new Bilstein shocks are, in my opinion, too soft and don't provide adequate rebound control. The OEM shocks were actually better. I will have to add air bags, I guess, and will replace the new Bilsteins when I find something better.
I am scheduled to pull a 5er from IN to ND tomorrow. I'll report on the new DTT rebuild after towing.
So far I am very pleased with the DTT transmission components and the job done by James Northrum. He keeps a clean, efficient one-man shop and got me in and out in a day and a half.
Harvey
Great write up thank You. I have the air bags and the onboard control system. It makes a hugh difference. Sometimes just by adding a pound or two make the difference. I also have the Demco Glide ride trailer replacement hitch pin. Between the two it like the trailer isn't even there. Except for the hills, of course. I'm gonna wait for something to happen to the transmission before replacing it.
HBarlow - welcome to the Wolf Pack! James Northum did my DTT build about a year ago and I've been nothing but smiles since. I had the "livestock" valve body mods done and it will chirp the tires on concrete when I hit second if I'm footin it.
Northum is a good dude and he certainly knows his diesels.
BGlidewell - call DTT at 866-504-4002 and ask them for James' number since he's a certified DTT builder, or send me a PM and I'll get his info to you.
I've put about 3500 miles on my new DTT or JTT transmission as James prefers to call it since his rebuild. I've pulled a couple of trailers with it already. It works great.
James is a hell of a nice guy. BTW, thanks JTRUELOVE for turning me onto him. I am gonna get him to install my injectors when I get around to getting them.
Yep... . James is a great guy and has become a good friend of mine. I wouldn't take my truck or transmission anywhere else! Oo.
High Ranger... not a problem. He is a very nice guy, that I don't mind referring people too. Be sure and tell him Joey sent ya. Good Luck, maybe we'll see ya around. Mine's a Black QC 4x4 with a topper on it.
CPittman,
Thanks for the link. I took a brief look at the website before calling Bill Kondolay and James Northrum but guess I didn't pay attention to the wolfpack logo.
I like the transmission a lot better now. I'm hooked up to a triple axle Alfa fifth wheel with a GVWR tag of 18,500# going to Hamilton, ON today. That should test the DTT-JTT transmission.
Harvey
oh i've tested my JTT-DTT to the max. Spun all 4 tires numerous times and with zero sign of transmission wear. i have i think 16 time slips from the track... . and permanent melted rubber to my fenders. James told me from day one that he "is NOT responsible for excessive tire wear!" :D
JTrueLove- a long time ago, i caught ya at the light at walnut grove and 287. at the time my truck was stock and you beat me (red 05 quadcab short bed 4x4)... . two weeks later James put the trans in along with some goodies. I'm up for a re-match! :) I'm originally from Midlothian but A&M has me consumed at the moment.
Cheers to DTT, I also just recieved a complete package less the billeted parts and I have to say I am very much satisfied with the transmission. I would highly reccommend this company to anyone out there. The customer service is as goood as it gets and the product is worth every penny. I still feel very sorry for recommending a at. s. to a good friend of mine who has had nothing but problems at the cost of seven thousand plus. His truck is still in the shop at almost two months waiting for so called warranty service and hardly any correspondence. Anyways just i just wanted to spread the word of the great DTT performance. Out!
