Engine/Transmission (1998.5 - 2002) DTT twins, towing and injectors
Engine/Transmission (1994 - 1998) 97 starting problems
Engine/Transmission (1998.5 - 2002) How to change a clutch.
I am getting a set of DTT twins. Which injectors would you go with and still be able to tow??? Let me know your thought's.
Mike L.
RMTDR President
I'd go with Mach 4's. You should be able to keep EGTs under control even in the altitude then.
If you're doing twins, a cam is a really good idea, too.
JMHO
What turbos is DTT going to use in their twins setup? Knowing how much air you will be moving may help in suggesting which injectors might work best.
Off the subject question, but I have to agree with Honn. If that head is coming off for any reason (studs, o-ringed, thicker gasket) slip a new cam in there.
You have been running dd3's for several years now with that 40, so EDM 4's or 5's should still keep you in the safe zone with Twins, providing they can light up fast enough, or keep the boost up under load (read - pulling up hill).
